Grand Am/IMSA Data Guy
Which oil pump to use
I am rebuilding a 72 T engine for street use. I need an oil pump. Which one is the best choice without breaking the bank? Thanks
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
Use what is called the 4 bar pump for the 4 ripples on the back of it.
You need to do the oil bypass mod but it's the same pump used through Carrera Bruce |
An SC pump will be a swap in and you'll be able to re-use the sump and screen. Also it's an aluminum pump which is very much an upgrade. Am bringing a couple to Hershey to sell. RR
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer |
Schleprock
The separate sump screen/venturi is not getting any younger and i've seen them break in the recent past. If I were looking for a pump, i'd get one from a Carrera 3.2 engine since it has the built in screen. The solution to the sump plate is get an aftermarket billet piece like Mainely or Burnham/Supertec
Kevin L '86 Carrera "Larry" |
gearhead
Just have Glenn Yee go through your stocker.
http://www.glennyeemotorsports.com/downloads/gt1_oilpumps.pdf
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
It's a 914 ...
Interesting. I like this idea. With the additional benefit of having someone knowledgeable go through the pump. They aren't getting any newer ... |
gearhead
I've visited Glenn in his shop and he walked me through his process. Next engine I build or have built will get one for sure.
3 restos WIP = psycho
Agree. Aaron Burnham once told me he could get an early pump to flow almost as well as a turbo pump just by fully relieving the internal breaking edges that interrupt flow. It's actually pretty simple to do yourself if you are handy with a Dremel.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
