-   -   anti seize in the wrong place? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/912724-anti-seize-wrong-place.html)
doublebuffle 05-02-2016 03:47 PM
Guys, i put antiseize on the engine and tranny mount bolts. Am i screwed?
Rawknees'Turbo 05-02-2016 03:54 PM
I always use anti-seize on those (though my cars have a gearboxes, rather than a "trannies" :eek: . . . not that there's anything wrong with that!!!:)).
prschmn 05-02-2016 04:07 PM
Later you'll be able to be unscrewed-----nah you're not
JFairman 05-02-2016 07:04 PM
A drop or two of motor oil on those threads works well too.
doublebuffle 05-02-2016 07:25 PM
Thanks guys, also... ehhh
911 Rod 05-03-2016 09:21 AM
I'm curious why you would think this is a bad thing?
KTL 05-04-2016 02:53 PM
The M12 engine mount bracket bolts (the bolts that pass through the body mounts) are notorious for rusting into the threaded tubes on the ends of the bracket. Antiseize is highly recommended thereb because when they rust, what can happen is the threaded tube tears away from the bracket when you try to break them loose with a long breaker bar or an impact wrench.
