Gunga Galunga
doublebuffle's Avatar
anti seize in the wrong place?
Guys, i put antiseize on the engine and tranny mount bolts. Am i screwed?
Old 05-02-2016, 03:47 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
I always use anti-seize on those (though my cars have a gearboxes, rather than a "trannies" . . . not that there's anything wrong with that!!!).
Old 05-02-2016, 03:54 PM
prschmn's Avatar
Later you'll be able to be unscrewed-----nah you're not
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 05-02-2016, 04:07 PM
A drop or two of motor oil on those threads works well too.
Old 05-02-2016, 07:04 PM
Gunga Galunga
Thanks guys, also... ehhh
Old 05-02-2016, 07:25 PM
Counterclockwise?
I'm curious why you would think this is a bad thing?
Rod
1986 Carrera
2001 996TT
Old 05-03-2016, 09:21 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The M12 engine mount bracket bolts (the bolts that pass through the body mounts) are notorious for rusting into the threaded tubes on the ends of the bracket. Antiseize is highly recommended thereb because when they rust, what can happen is the threaded tube tears away from the bracket when you try to break them loose with a long breaker bar or an impact wrench.
Kevin L
'86 Carrera "Larry"
Old 05-04-2016, 02:53 PM
