Well, 1.25 is a good deck height, I'd use that. Again, you will not get exactly the same readings around the piston because of the piston rock as a result of the piston/wall clearance. Set your piston dome even with the cyl. top like you did with the straight edge and then measure down to the lip with the caliper and compare that to the .525" that JE says the dome height is.
Old 05-17-2016, 06:04 AM
Under the radar
Trackrash's Avatar
Hijack
My burette finally arrived.
In my case, my 9.5 JE pistons, spec'ed out as specified.
Deck height at 1mm with .25 base gaskets.
Here I'm confirming the dome height, .400" or 1.016cm
Here I'm verifying the dome volume. 39.4ml. Spec is 39.8.
With my heads measuring 89ml my CR comes in at 9.8 to 1. Right where I want to be.
BTW, I used Excel to do my calcs. Makes it easier to fiddle with the numbers.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-09-2016, 08:25 PM
Under the radar
Trackrash's Avatar
Forgot to post the spec sheet.
Gordon
Old 06-09-2016, 08:28 PM
