Journalist
AdamKaz's Avatar
Charred Gunk in Exhaust Port???
What in sweet fancy moses is this stuff?
This charcoal looking stuff is rock hard, most prevalent near the front of the car and decreasing in severity as you move down the cylinders towards the rear of the car. This is the most extreme example is cylinder #1.
Is this a symptom of impending disaster, or just a side effect of air cooled oily goodness?
"The Rain" 1988 911 Carrera Coupe
"The Dog" 1970 BMW 2002
"The Saint" 2012 BMW G650 GS Sertao
Old 05-17-2016, 05:39 PM
Under the radar
Trackrash's Avatar
Kinda hard to tell from the picture. How thick is it?
How much oil is your car using? What do the plugs look like?
I would check the valve guides for wear.
My 2,5L motor that has 100K miles since its rebuild had a thin coating, maybe a mm or 2, of hard carbon. And my valve guides are shot.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-17-2016, 07:37 PM
Looks like coked oil from bad guides.
Old 05-18-2016, 05:58 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep that's what it is and bad valve guides is what causes it to happen
Kevin L
'86 Carrera "Larry"
Old 05-18-2016, 08:43 AM
KTL KTL is offline
Schleprock
KTL's Avatar
And I'll add that a can of Berryman B12 Chemtool in your gas tank will clean that stuff up in one tank of gas usage. Obviously it doesn't fix the actual problem but it does clean up the mess!
You saw Elaine's dancing recently? (I'm a Seinfeld addict, watch it all the time!)
Kevin L
'86 Carrera "Larry"
Old 05-18-2016, 08:46 AM
Journalist
AdamKaz's Avatar
Thanks everyone. Looking around I see that worn guides are a pretty common problem for the 3.2. I'll check the spark plugs today, but unless they are crazy bad I'll likely button it back up and drive it for 50k or so before a total rebuild/upgrade.
Thanks for the help!
Old 05-18-2016, 11:41 AM
abit off center
cgarr's Avatar
Or the wife been driving the car?
Craig
G2Performance
Old 05-18-2016, 11:48 AM
You should remember that when the guides get worn sufficiently to display such oil deposits, they are not cooling very well and this increases the chances of a failure.
Now THAT is far more expensive to repair than a normal valve job.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-18-2016, 11:42 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Thankfully me wifey can't drive a manual transmission
Kevin L
'86 Carrera "Larry"
Old 05-19-2016, 08:21 AM
