Mate 3.6 jugs to 3.8 heads?
I have a set of 964 heads that were cut flat to mate to 3.8 jugs.
However, I'm thinking of downsizing the jugs to run a 3.6 setup. I'd like to reuse the heads as they have been reconditioned and they are setup to use the RS 51.5mm intakes and 43.5mm exhausts with 8mm valves. thoughts? thanks, Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
If the chambers haven't been messed with I don't see it being a problem.
As long as you have a seal surface you ought to be fine-maybe just a touch of quench area around the perimeter?
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
