After engine overhaul miles before oil change valve adjust
Top end overhaul on 3.2 how many miles before first oil change and valve adjust, thanks
Just the heads? Or new rings, etc.? Think 1st valve adjust is ~ 1100 miles.
Todd |
New rings also
Mine was run on the dyno, so I didn't do the first interval which I think is 100 miles. I did a 500 mile change. I'm also changing mine while I do my after break-in valve adjust, but that is mostly because it's taken me a year to drive ~ 1100 miles. All things being relative, oil is cheap (even the good stuff).
Todd |
I would crack her open to make sure all is fine way before that. Heck, it is only little oil loss and valve cover gaskets, if that.
Then 1000-1100 miles later do the valve adjust, check torque of rocker shafts and oil change. Do a partial drop and remove cat/bypass if you want easier access. ( I personally hate adjusting valves with engine in the car but a partial drop is easier, removal is of course better ) |
| All times are GMT -8. The time now is 07:21 PM. |
