Send a message via Skype™ to SorenDK
EFI parts
Hi
This question is for you guys who has done a CIS to EFI upgrade on the CIS intake manifold: What injectors are you using? - anyone experimented with injectors from other car makers?
Have you guys used other parts from other cars with succes in the CIS to EFI transformation?
I have a 1977 2,7 engine, a DC-20 cam and 10,1:1 JE. now going for a megasquirt setup based on a '78 CIS intake ...
Thanks from Søren
My 69E project ...
http://www.youtube.com/user/ditster666
Old 06-22-2016, 01:32 PM
E-85 sippin drunk
turbobrat930's Avatar
Soren,
It depends on a few different factors...
1. What does MS require? Low or high imp injectors?
2. What is your fueling requirements? ( what size cc injectors are you needing)
In a short answer, yes... you can use injectors from other vehicle manufacturers, as long as they meet your ECU and fueling requirements. You will just have to do a little research.
One question for you. How do EFI injectors fit in the intake where the CIS injectors used to be? Coming from the 930 world, I know that they have injector blocks that they buy that the newer, EFI injectors fit into...
And kudos to you for jumping into the EFI world. You will LOVE IT!!!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 06-23-2016, 06:30 AM
jsveb's Avatar
Hej Søren
Are you familiar with tbitz? It is somewhat dated now, but still a great almost plugandplay MS based efi system. There are loads of info on this forum, worth spending the time reading.
Good luck
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 06-23-2016, 02:38 PM
a great starting point is the tbitz system. Thats what I did and would do it again
80SC (ex California)
Old 06-24-2016, 10:44 AM
Puny Bird
Mark Henry's Avatar
Originally Posted by SorenDK View Post
Hi
Thanks from Søren
The CIS intake will be a bit of a choke point, not really known for good flow.
Look for something like 35lbs high impedance injectors. I think Ford red tops are about that.
You are looking for no more than a 80% duty cycle so if your max would be 40lbs than you would want at least a 50lbs injector. That's ballpark, and BTW you also don't want injectors off of a L-jet car.
Do a google search there's a couple of sites that have injector rates and info for different cars.
MS and most systems use high impedance injectors, but all can use low impedance with the correct resistor pack.
My VW bug (180hp T4 engine) uses Siemens Deca 55lbs low impedance injectors.
sdsefi.com has excelent FAQ and tech sections.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-24-2016, 07:33 PM
Turbonut
Raceboy's Avatar
2.7 with mods would probably put you near 240-250 hp maximum so you would need ~270-280 cc injectors and that leaves you enough headroom so you won't exceed 90% duty cycle. Modern injectors can easily be ran up to 95% duty still having control over them, old fat ones need more.
I would definitely prefer newer style ones, much better control.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 06-25-2016, 10:30 AM
jdbunda's Avatar
I about to do a MS system on my 3.0, but not using the CIS intake. I will be using MFI ITBs and intake. My heads have been drilled for MFI injectors, and using the Classic Autowerks adapters (our host sells) I will be using Siemens Deka high impedence injectors from a BMW 328i.
John
1972 911T 3.0L Coupe
1986 Carrera Targa
1989 BMW M3
2007 328iT
Old 06-29-2016, 01:05 PM
Thanks for all these excellent inputs. I am working on a shortlist of parts to get and with your inputs I have come a good way.
I think the best way to do this is to start with the basics and from there expand the setup. I'm sure you will agree with me that things to p cars quickly erodes a budget :-)
An ITB setup is preferred but I will start off with the CIS intake for now - to get things going and gather experience. What to choose... Mega squirt 1 or 2?
My 69E project ...
Old 06-30-2016, 11:19 AM
