-   -   Biral Cylinders question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/919441-biral-cylinders-question.html)
FOZZY 06-24-2016 06:37 PM
I need to change the cylinders on my 911 1971.
I found this 84mm Porsche 911 2.2/2.4 Engine Biral Cylinder Set on AA Performance website:
84mm Porsche 911 2.2/2.4 Engine Biral Cylinder Set | AA Performance Products
Does anybody can tell me if it is an acceptable quality for a car to be driven less than 5000 miles per year and no track racing?
Thanks,
Francois
Mark Henry 06-24-2016 07:36 PM
Do a search of this forum, this question has come up many times before.
Trackrash 06-24-2016 07:52 PM
In theory those are nice cylinders. I would want to know if they have been honed or bored over size. I can't imagine they are stock size and in spec.
Once you have a machinist figure out if the cylinders are in spec the next step is finding some matching pistons.
You might want to shop around.
pors1968 06-25-2016 03:33 AM
Hi MARK did you use them lately i might be interrested to use them for stock 2.2T.THANKS
chris_seven 06-25-2016 05:58 AM
There is a guy in the UK who seems to have experienced issues but he bought Barrels and JE Pistons as a set.
The clearances were apparently poor.
When he published numbers the barrel diameters at 84mm looked bang on but piston ring gaps were horrid.
They barrels/pistons arrived assembled and no-one took them apart and made any checks before building the motor.
I have seen the barrels and they look OK.
Mark Henry 06-25-2016 06:33 AM
I've only used the iron cylinders for the type 4 builds, they seem to be OK quality, but about 15,000km is all I have on a set, so long term value is still unknown.
I won't use AA pistons or the grant rings they sell, I use Hastings (96mm, KB pistons) or Deves rings for stock sizes.
FOZZY 06-25-2016 06:50 PM
Thanks to all for your responses.
tom1394racing 06-26-2016 04:07 AM
If you buy them, measure them for bore size, ovality and taper. Also check the cylinder heights. The one set I used had one cylinder that was too high and had to be machined to match the other five.
