-   -   Gasket Stuck On Case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/920329-gasket-stuck-case.html)
arbita1 07-02-2016 04:58 AM
How do you remove the old paper gasket when it is stuck on the case. It's the gasket for the chain housing where it meets the case. I had the case hot tanked but that didn't get it off. Yesterday I was trying brake cleaner and very carefully removing with a razor blade. I got some off but I don't want to risk scratching the case.
Flat6pac 07-02-2016 05:57 AM
Usually around the stud, I would pull the stud if I needed to get the gasket off.
When installing the gasket, I put 574 on the bottom 2 inches where it might be immersed in oil
Keeping gasket removal problems to a minimum in the future.
Bruce
Steve@Rennsport 07-02-2016 09:28 AM
A single-edge razor blade and a lot of patience.
Matt Monson 07-02-2016 11:12 AM
3m makes an adhesive remover you can get at a hardware store. I apply that, let sit 10-15 minutes and turn razor blade. Makes a huge difference in effort.
And just 574 with no gasket when you reseal it.
kevin930t 07-02-2016 11:38 AM
U mighy want to use a plastic rotary disc with brissles,with a right angle if u can get it in there
Sent from my SM-N910T using Tapatalk
kevin930t 07-02-2016 11:39 AM
http://uploads.tapatalk-cdn.com/2016...b85d2acb68.jpg
