Gasket Stuck On Case
How do you remove the old paper gasket when it is stuck on the case. It's the gasket for the chain housing where it meets the case. I had the case hot tanked but that didn't get it off. Yesterday I was trying brake cleaner and very carefully removing with a razor blade. I got some off but I don't want to risk scratching the case.
Matt. 83 911SC 85.5 944 NA - Sold |
Usually around the stud, I would pull the stud if I needed to get the gasket off.
When installing the gasket, I put 574 on the bottom 2 inches where it might be immersed in oil Keeping gasket removal problems to a minimum in the future. Bruce |
A single-edge razor blade and a lot of patience.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
gearhead
3m makes an adhesive remover you can get at a hardware store. I apply that, let sit 10-15 minutes and turn razor blade. Makes a huge difference in effort.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
gearhead
And just 574 with no gasket when you reseal it.
U mighy want to use a plastic rotary disc with brissles,with a right angle if u can get it in there
Sent from my SM-N910T using Tapatalk |
![]() Sent from my SM-N910T using Tapatalk |
