-   -   Machine shop - Case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/920938-machine-shop-case.html)
FRANKENSTIEN 07-07-2016 11:46 AM
Machine shop - Case
Hello,
I've recently taken the challenge of rebuilding my 1978 3.0L engine. I have the case split, hot tanked, and cleaned multiple times.
I'm ready to send my Crankshaft out to be inspected. All the bearings look good, no scratches or marks. Should I also send the rods to be looked at as well?
thank you.
Tippy 07-07-2016 11:58 AM
Absolutely. If it rotates, it should be looked at IMO.
More than likely, the big ends are ovalled and need to be resized.
turbobrat930 07-07-2016 12:06 PM
Yes!
Then, they can inspect everything, install new rod bolts and install the rods on the crank for you. That way, you have the piece of mind that they are installed correctly (using stretch gauge).
I do not know what your plans are, but I would highly recommend that you use ARP rod bolts.
Steve@Rennsport 07-07-2016 03:30 PM
Originally Posted by FRANKENSTIEN (Post 9189953)
Hello,
thank you.
The rod big ends should be be resized, small ends measured and possibly re-bushed, and the end-to-end lengths corrected as needed so they are all the same. You would be surprised at the production tolerances in rod lengths that cause problems setting consistent deck heights.
The oil galley plugs in the crank should be removed and all the passages cleaned after inspection.
Tippy 07-07-2016 06:02 PM
Ah yes, rebush the little ends. Forgot that important piece!!!
FRANKENSTIEN 07-08-2016 12:56 PM
Thank you fellow pelicans for the vital information, I'm thinking of using this machine shop in Inglewood, CA called Engine machine service. Anyone used them before? Trustworthy?
Thank you
rkeele 07-09-2016 04:14 PM
heard they were good, was going to use them but because I had used Ollies in the past to mod my 964 cyl. heads stayed with them.
Drbraunsr 07-09-2016 09:11 PM
EMS (Dick) recently machined my Carrera heads for twin plug and freshened everything up.
Very pleased with the quality with a reasonable price.
They are a full service machine shop and understand Porsche-speak
