-   -   shiftknob inserts (http://forums.pelicanparts.com/911-engine-rebuilding-forum/921783-shiftknob-inserts.html)
speedo 07-14-2016 07:16 PM
shiftknob inserts
Anybody know a source of the inserts with set screws for the early shift knobs to slip onto and to secure to 901-911-915 shifters? And are they glued in?
Speedo
Mark Henry 07-14-2016 08:32 PM
Speedo
I think you mean a crush ring sleeve, but they don't have a set screw, only the aftermarket knobs have a set screw IIRC.
4th item down, 914 trans is a 901.
Porsche 914, 914-6 (1970-1976) - Shift Linkage - Page 1
speedo 07-14-2016 08:57 PM
shift knob stuff
Not the crush sleeve. But definitely the aftermarket insert. For example, an aftermarket AMCO used an insert and some of those used crush sleeves and some used set screws. There are some manufacturers that are producing balsa shiftknobs...maybe I should search there...:confused:
Speedo
Mark Henry 07-15-2016 03:35 AM
Know someone with a lathe ;)
Or a WTB for an old worn out amco.
speedo 08-17-2016 06:51 PM
Good idea!
This ought to work....
http://forums.pelicanparts.com/uploa...1471480175.jpg
http://forums.pelicanparts.com/uploa...1471480189.jpg
http://forums.pelicanparts.com/uploa...1471480205.jpg
This is a very nice crest on the knob. The wood deserves to be carefully refinished...
http://forums.pelicanparts.com/uploa...1471480222.jpg
Which is what I will do next!
