shiftknob inserts
Anybody know a source of the inserts with set screws for the early shift knobs to slip onto and to secure to 901-911-915 shifters? And are they glued in?
Speedo
Old 07-14-2016, 07:16 PM
Puny Bird
Mark Henry's Avatar
Speedo
I think you mean a crush ring sleeve, but they don't have a set screw, only the aftermarket knobs have a set screw IIRC.
4th item down, 914 trans is a 901.
Porsche 914, 914-6 (1970-1976) - Shift Linkage - Page 1
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 07-14-2016, 08:32 PM
shift knob stuff
Not the crush sleeve. But definitely the aftermarket insert. For example, an aftermarket AMCO used an insert and some of those used crush sleeves and some used set screws. There are some manufacturers that are producing balsa shiftknobs...maybe I should search there...
Speedo
Old 07-14-2016, 08:57 PM
Puny Bird
Mark Henry's Avatar
Know someone with a lathe
Or a WTB for an old worn out amco.
Old 07-15-2016, 03:35 AM
Good idea!
This ought to work....
This is a very nice crest on the knob. The wood deserves to be carefully refinished...
Which is what I will do next!
Old 08-17-2016, 06:51 PM
