-   -   Connecting rod bolts torque (http://forums.pelicanparts.com/911-engine-rebuilding-forum/924918-connecting-rod-bolts-torque.html)
FRANKENSTIEN 08-09-2016 06:37 PM
Hello all,
I have a 1978 911 sc
I'm ready to torque my connecting rod nuts to the crank shaft but I'm not sure if it's:
1. Torque bolts to 14.7 lbs
2. 90 degree
Or
2. 90 degree
3. Another 90 degree
Thank you
DRACO A5OG 08-09-2016 08:05 PM
Per Porsche Tech Manual for a 3.2
M10 X 1.25 = 20Nm plus (1) 90 degree torque angle ( +/-2 degrees )
But please wait for someone with your year to confirm.
Credit to KTL for sharing the info.
boyt911sc 08-09-2016 08:08 PM
Specify what type of Conrod bolts......
Originally Posted by FRANKENSTIEN (Post 9234433)
Hello all,
2. 90 degree
Or
2. 90 degree
Thank you
Frank,
Nobody would be able to advise what torque value you would need without knowing the kind or type of rod bolts you are using. Porsche OEM rod bolts? ARP? Raceware? Etc. Please be more specific. Thanks.
Tony
DRACO A5OG 08-09-2016 08:14 PM
Aftermarket would definitely have their specific torque requirements. At least the ones I bought. :-o
proffighter 08-10-2016 03:12 AM
Manual is not up to date... Depending on bolts (BTW I would change 30years old ones)
http://forums.pelicanparts.com/uploa...1470823915.jpg
http://forums.pelicanparts.com/uploa...1470823929.jpg
FRANKENSTIEN 08-11-2016 06:21 PM
I have new oem bolts from porsche.
Do I attempt the second 90 degree torque?
winders 08-11-2016 06:31 PM
Do the bolts match Figure 1 or Figure 2?
Jeff Alton 08-11-2016 07:40 PM
The above Technical bulletin is NOT applicable to your rod bolts. This if for updated 3.2/3.3/3.6 bolts which are 9mm. Your rod bolts are 10mm. Ignore the bulletin.
winders 08-11-2016 08:37 PM
Good catch, Jeff.
proffighter 08-12-2016 03:44 AM
Sorry, did not noticed which engine you have
