Connecting rod bolts torque
Hello all,
I have a 1978 911 sc
I'm ready to torque my connecting rod nuts to the crank shaft but I'm not sure if it's:
1. Torque bolts to 14.7 lbs
2. 90 degree
Or
2. 90 degree
3. Another 90 degree
Thank you
Old 08-09-2016, 05:37 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Per Porsche Tech Manual for a 3.2
M10 X 1.25 = 20Nm plus (1) 90 degree torque angle ( +/-2 degrees )
But please wait for someone with your year to confirm.
Credit to KTL for sharing the info.
'85 Carrera Targa
PCA/POC
Old 08-09-2016, 07:05 PM
Specify what type of Conrod bolts......
Originally Posted by FRANKENSTIEN View Post
Hello all,
2. 90 degree
Or
2. 90 degree
Thank you
Frank,
Nobody would be able to advise what torque value you would need without knowing the kind or type of rod bolts you are using. Porsche OEM rod bolts? ARP? Raceware? Etc. Please be more specific. Thanks.
Tony
Old 08-09-2016, 07:08 PM
DRACO A5OG's Avatar
Aftermarket would definitely have their specific torque requirements. At least the ones I bought. :-o
'85 Carrera Targa
PCA/POC
Old 08-09-2016, 07:14 PM
proffighter's Avatar
Manual is not up to date... Depending on bolts (BTW I would change 30years old ones)
Roland
930 Turbo '81 Too many modifications to list
Old 08-10-2016, 02:12 AM
I have new oem bolts from porsche.
Do I attempt the second 90 degree torque?
Old 08-11-2016, 05:21 PM
Racer
winders's Avatar
Do the bolts match Figure 1 or Figure 2?
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 08-11-2016, 05:31 PM
Jeff Alton's Avatar
The above Technical bulletin is NOT applicable to your rod bolts. This if for updated 3.2/3.3/3.6 bolts which are 9mm. Your rod bolts are 10mm. Ignore the bulletin.
www.turn3autosport.com
Old 08-11-2016, 06:40 PM
Racer
winders's Avatar
Good catch, Jeff.
Scott Winders
PCA GT3 #3
Old 08-11-2016, 07:37 PM
Sorry, did not noticed which engine you have
Roland
Old 08-12-2016, 02:44 AM
