-   -   2.2 Crankshaft play (http://forums.pelicanparts.com/911-engine-rebuilding-forum/925441-2-2-crankshaft-play.html)
eddied 08-14-2016 08:02 AM
2.2 Crankshaft play
So my starter ate my ring gear, and I could not imagine why, until I was removing the flywheel bolts. The first one I touched the flywheel backed out about 1/2". Here's a wobbly video. Thrust bearing?
https://youtu.be/ipsfhOvMthI
DRACO A5OG 08-14-2016 08:50 AM
Wow, that is allot of movement. I recently did work on my engine and noticed the in and out play but only 1MM or so.
But once I put the crank pulley back on, slop was gone. Is your pulley removed?
Also, is it the video or does the crank really appear cockeyed like that?
eddied 08-14-2016 09:42 AM
The pulley is still on, I'm waiting for cam tools to arrive, and then i will get to the bottom of this. I one handed the camera, while I turned with the other. I just can't believe the amount of movement
DRACO A5OG 08-14-2016 10:00 AM
I had to resurface my crank pulley end and it was super annoying every time I turned it to insure evenness, kept jump in and out causing my dial to go crazy :eek:
Question, when you pulled the ring off, did you gradually remove it by removing each nut equally? I am sure you did but just incase you didn't install it te same way it could warp the starter ring gear.
eddied 08-14-2016 10:27 AM
215mm clutch, integral ring gear http://forums.pelicanparts.com/uploa...1471195558.jpg
Flat6pac 08-14-2016 01:16 PM
The pulley shouldn't have any bearing on the thrust. All thrust should be handled by bearing #1 on crank. #8 is oil control, not thrust. That much play has to affect the distributor and timing inside on the crank.
Bruce
eddied 08-14-2016 01:22 PM
Can #1 wear that much without damaging the crank?
prschmn 08-15-2016 04:15 AM
Even if the thrust faces were gone I'm not ure it would account for all that slop.
As was mentioned-is the face not square with the case?
That would be a busted crank.
And as Bruce said-the pulley shouldn't make any difference.
Either way you need to split the case but I'm afraid it's going to get ugly in there.
Sorry
Though I have a good crank here . Hopefully the case isnt damaged.
eddied 08-15-2016 07:16 AM
I think the seal is cockeyed http://forums.pelicanparts.com/uploa...1471270249.jpghttp://forums.pelicanparts.com/uploa...1471270350.jpg
Rusty 356 08-17-2016 10:41 AM
Crank endplay and runout?
