Puny Bird
Valve springs, when should you upgrade to heavier springs?
The thread below started me thinking about when you should upgrade to heavier springs.
Valve Springs Upgrade Worthwhile? 3.0 SC I'm in agreement that a stock engine only needs stock springs, but in the thread it may leave some thinking you need the heavy springs for racing only. Many have mild to very hot street engines with aggressive cams, twin plug, turbo, run higher RPM, rev faster, etc. My origins is from the VW world and anything over the stock cam I would run HD springs, but I also know that a pushrod valve train is a different animal from the overhead cam the six uses. At what point do you start worrying about valve float? Pros and cons of running heavier springs and while we are on the subject what spring combo's have you used.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
I use 993 springs in my current 964 based track engine.
In the race engine I am building -- I am moving to EBS racing springs. I have a fabcar shifter that I added a spring to cock the throw to the right. This requires me to pull the shifter left to downshift. For me this is a little safeguard during shifting that the accident is a missed shift going to a higher gear, and not the other way around. ymmv, Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
There are many choices and some of them are pretty stiff, resulting in higher rates of wear on intermediate shaft gears, chains, sprockets, idlers, cams & rocker arms. One can easily see the consequences of using (too) stiff valve springs so such decisions should be taken very seriously.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
