-   -   Cam Tower (http://forums.pelicanparts.com/911-engine-rebuilding-forum/928877-cam-tower.html)
grip 911 09-13-2016 05:18 PM
Cam Tower
Will a 964 cam tower work on a 3.0liter or 3.2 motor?
Flat6pac 09-13-2016 05:22 PM
Yes but you lol need valve covers to match as the studs are 6 mm instead of 8 mm.
The early 964 castings were used as early as 1988 series but with correct 8mm studs
Bruce
prschmn 09-14-2016 06:14 AM
I'm not so sure it's that easy-the oil feed arrangement is different.
Maybe it would be possible to tap the hole in the carrier to accept
the 10MM hollow bolt?
