Cam Tower
Will a 964 cam tower work on a 3.0liter or 3.2 motor?
Old 09-13-2016, 04:18 PM
Yes but you lol need valve covers to match as the studs are 6 mm instead of 8 mm.
The early 964 castings were used as early as 1988 series but with correct 8mm studs
Bruce
Old 09-13-2016, 04:22 PM
prschmn's Avatar
I'm not so sure it's that easy-the oil feed arrangement is different.
Maybe it would be possible to tap the hole in the carrier to accept
the 10MM hollow bolt?
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 09-14-2016, 05:14 AM
