-   -   QSC pistons camshaft options (http://forums.pelicanparts.com/911-engine-rebuilding-forum/929656-qsc-pistons-camshaft-options.html)
lvporschepilot 09-21-2016 05:21 AM
Quick question all, do QSC pistons have adequate clearance for high lift cams, or must CIS cams be used? I see QSC does not have valve pockets so my answer was no but I want to be certain.
tharbert 09-21-2016 07:09 AM
I don't think you'll find anyone here with a lot of experience with QSC pistons. I do know that AA offers a number of options that include JE forged pistons, some with high compression domes with significant valve relief pockets.
May I suggest you provide a lot more information about what you want to build. Going with high lift cams brings a whole different set of concerns besides fitment. You may be stepping right out onto that proverbial slope and when you start with QSC parts, I might be wrong but I don't think this is an unlimited budget build.
Henry Schmidt 09-21-2016 08:17 AM
The issue with QSC is that they don't have hands on experience with their products.
In the early days of QSC, I offered them advise (in response to their inquires) and tested many of their products.
My experience is that they ignore experienced based, real world information.
Many of their products are also labeled incorrectly. Another example of their lack of expertise.
Some of their products are cost effective and reasonable quality but it's a challenge to separate the wheat from the chaff.
Tom_in_NH 09-21-2016 11:37 AM
I know of at least one forum member that used QSC cylinders in his rebuild. I believe it was Laprikis (sp) ?
lvporschepilot 09-21-2016 12:00 PM
Not my build guys. A local guy I run with at Road Atlanta asked about 'those cheap pistons/cylinders on ebay' to which I replied I have zero idea with them having no valve pockets what cam one could use with them. With how reasonable JE shelf pistons are for these things it's a no brainer to me. If someone were tearing their engine down every season it might be worth running for funzies
I try not to knock Chinese stuff too much because most of our road cars, Toyota, Honda, Kia, Hyundai, the list goes forever, are indeed running many internal rotating components, including pistons, from you got it, China. That said, I'm sure specifications are much more tightly controlled by those manufacturers where a small order is 200,000 pistons.
2jmotorsports 09-21-2016 12:47 PM
On a different note what a cool source for hot rod VW stuff!
