Removing the crankshaft pulley bolt
I am trying to remove the crankshaft bolt so I can repair a leak. My impact gun is too long to fit under the partially dropped engine, so I am resorting to trying to undo it with a breaker bar. What I am concerned about is how to undo the bolt without the crankshaft moving. Am I correct, that the crankshaft must not be moved or I will be in trouble?
This is on a '76 Carrera.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
Under the radar
Fifth gear, parking brake on?
Disconnected the coupler because this is a partial engine drop.
Are you saying I should pull the parking brake, and will that be enough not to spin the crankshaft? A big-ass breaker bar is just going to turn the engine over, backwards, even if I have somebody hold the brakes.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 09-05-2015 at 03:28 PM.. |
Can you get a swivel socket in there?
Probably
Under the radar
I would try the brakes. If the parking brake doesn't do it have someone press the brake pedal. You still can select 5th using the shift rod.
If that doesn't work, does the pulley have holes in it?
Have I got this all wrong with the brake pedal and the emergency hand brake affecting the wheels only and not the engine? Yes, the pulley has 2 holes.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 09-05-2015 at 07:50 PM.. |
Under the radar
I would try that, if it doesn't work, jamb something through the hole in the pulley to lock it.
Someone mentioned putting a screwdriver into the ring gear. What do you know about that?
Banned
Personally, I would do whatever it takes to get an air-impact in there - a quick pull of the trigger and the bolt is out with no need to hold the pulley at all . . .
Functionista
Engine turns clockwise so you could use the time honored back yard Billy method.
Ie; quick burst of starter after bracing the breaker bar firmly. |
Chain fence eating turbo
Mine was so hard to get out, I couldn't believe it. Craftsman 1/2" impact almost could not break it. I pulled out a 3/4" impact, but didn't have the socket needed. After several minutes of rapping on it, it finally broke free.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel Last edited by Tippy; 09-06-2015 at 11:30 AM.. |
Are those available as a rental. My cordless won't touch that bolt.
Would you think its best to have have someone back there as well?
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 09-06-2015 at 09:02 AM.. |
Misspelled. Rapping, like beating on it for a long time.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
And how did you prevent the crank from turning?
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 09-06-2015 at 02:39 PM.. |
There should be no problem with the crank turning while you loosen the bolt. Once it's broken loose you can always turn the crank and put it where you want it before completely removing the bolt. The pulley is indexed with a pin to the crank, so it will only fit back on one way.
Rod Schneider Ball Ground, GA 88 928S4, 87 Corvette, 88 Fiero GT, 16 Mustang EcoBoost |
Good to know, thanks.
Here's an update. Put the wife in the driver's seat with the gear in 5th, parking brake on, without hardly any affect on stopping the crankshaft from turning. The crank shaft turned without hardly any torque on the bolt. Maybe there is so much play in the drive train that I should have moved the breaker bar further than I went. I went from 8 o'clock to 4 o'clock with hardly any resistance.
Next step is finding out how I can get an air impact wrench for a few minutes of work.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 09-06-2015 at 04:54 PM.. |
