 Supertec 10-mm x 1.25 cylinder head stud torque spec...... Deleted. Henry sent me the information. Tony |
 Any chance you can pass along? I'm assembling my engine with supertec studs as well. Looking for info on which thread lube to use and also torque spec |
 Did yall lose the spec sheet? |
 Previous owner had the engine built. I'm rebuilding the engine and have no documentation |
 SUPERTEC PERFORMANCE HEAD STUD KIT INSTALLATION INSTRUCTIONS 1) USE BLUE LOCTITE ON CASE END (10 x 1.50) 2) WE SUPPLY SUPERTEC THREAD LUBE WITH EACH KIT BUT YOU CAN USE LIGHT WEIGHT MOTOR OIL OR ANTI SEIZE ON CYLINDER HEAD END 3) CLEAN CASE THREADS COMPLETELY We recommend a thread forming tap (1.50x10 PD-6 6-N) for this application 4) TO INSTALL STUDS, DOUBLE NUT WITH THE GOLD NUTS PROVIDED 5) INSTALL STUD UNTIL IT BOTTOMS AND TURN OUT 1/4 TURN ******DO NOT FORCE THE STUDS INTO THE CASE******* 6) INSTALLATION LENGTH IS NO LONGER RELEVANT TORQUE SPECIFICATION + or – 2lbs STANDARD TORQUE PATTERN IS MAINTAINED a. 2.0 aluminum case 30 lb/ft b. 2.0, 2.2, 2.4, 2.7 ( all magnesium cases ) 26 lb/ft c. 3.0, 3.2, 3.6 aluminum case 30 lb/ft d. 3.0, 3.3, 3.6 aluminum Turbo 32-36 lb/ft THERE IS NO RETORQUING NECESSARY |
 Thanks! |
| All times are GMT -8. The time now is 05:10 PM. |
