Supertec 10-mm x 1.25 cylinder head stud torque spec......
Deleted. Henry sent me the information.
Tony Last edited by boyt911sc; 10-08-2016 at 04:33 PM.. Reason: delete |
Any chance you can pass along? I'm assembling my engine with supertec studs as well. Looking for info on which thread lube to use and also torque spec
-Rich- 1984 911 Track 1985 911 Track/Autocross |
Chain fence eating turbo
Did yall lose the spec sheet?
Previous owner had the engine built. I'm rebuilding the engine and have no documentation
Try not, Do or Do not
SUPERTEC PERFORMANCE HEAD STUD KIT INSTALLATION INSTRUCTIONS
1) USE BLUE LOCTITE ON CASE END (10 x 1.50) 2) WE SUPPLY SUPERTEC THREAD LUBE WITH EACH KIT BUT YOU CAN USE LIGHT WEIGHT MOTOR OIL OR ANTI SEIZE ON CYLINDER HEAD END 3) CLEAN CASE THREADS COMPLETELY We recommend a thread forming tap (1.50x10 PD-6 6-N) for this application 4) TO INSTALL STUDS, DOUBLE NUT WITH THE GOLD NUTS PROVIDED 5) INSTALL STUD UNTIL IT BOTTOMS AND TURN OUT 1/4 TURN ******DO NOT FORCE THE STUDS INTO THE CASE******* 6) INSTALLATION LENGTH IS NO LONGER RELEVANT TORQUE SPECIFICATION + or – 2lbs STANDARD TORQUE PATTERN IS MAINTAINED a. 2.0 aluminum case 30 lb/ft b. 2.0, 2.2, 2.4, 2.7 ( all magnesium cases ) 26 lb/ft c. 3.0, 3.2, 3.6 aluminum case 30 lb/ft d. 3.0, 3.3, 3.6 aluminum Turbo 32-36 lb/ft THERE IS NO RETORQUING NECESSARY
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 04-16-2017 at 07:42 AM.. |
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks!
