Advice needed on how to remove and replace Weber IDA 3C galley plugs
I am rebuilding my Weber IDA 3C's. I need to remove the lead (?) galley plugs so I can completely clean the gallies.
Does anyone have any advice on how to remove the plugs? Also any advice on replacing them would be much appreciated.
Old 11-02-2016, 04:21 PM
Drill them. Start small and then use correspondingly larger bits to remove all the lead without touching the carburetor body.
I've used small lead fishing weights and modified them to suit, but you may be able to find small lead balls at McMaster-Carr.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-02-2016, 11:16 PM
Shot Gun Cartridge manufacturers - I bought a jar weighing about 2 lbs 5 years ago and will never run out.
You will need a small punch to tap them down and we made one which puts the same 'witness' in the pug as the original.
Old 11-03-2016, 12:49 AM
Chris,
Most shot shells are now steel in this country.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-04-2016, 09:19 PM
We still use lead here in the UK and I can't imagine using steel shot in the barrel of my old Purdey - the very idea is scary.
Old 11-05-2016, 12:53 AM
Any thoughts on putting a small dab of jb weld over the lead plug once I install them as insurance?
Old 11-05-2016, 04:18 PM
I sure would never do such a thing. One day, you'll need access and its far easier to drill out the lead plugs, compared to doing the same and having that mess all over the carb bodies.
Plus, it will really devalue them.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-06-2016, 12:39 AM
Henry Schmidt taps the galleries and fits a 'grub' screw with a Loctite sealant.
Old 11-06-2016, 01:41 AM
