TAV TAV is offline
Help with rod bearing sizes
I'm going to start a rebuild of 1990 964 3.6 engine next year and just collecting some parts now.
I'm looking to get some clevite rod bearings, but noticed they come in more than size.
Standard vs 0.25mm oversize.
I'm assuming I need the standard, but
1) just wanted to clarify before purchase
2) curious when the oversize is used, what scenario?
Thanks in advance.
Old 11-10-2016, 12:41 PM
I am not an expert by any means of the word first and foremost.
I think the only time oversized is used is if the crank has been machined down due to scoring or other damage.
I would just make sure the crank is checked and repaired if needed
I think most Porsche cranks are repaired and brought back to oe spec if needed
Old 11-10-2016, 12:46 PM
TAV TAV is offline
Thanks for the prompt response crashtest.
Old 11-10-2016, 01:02 PM
no worries...I am sure another will chime in to verify
Old 11-10-2016, 04:24 PM
Chain fence eating turbo
Yep, unless machined from a prior rebuild or oiling issues causing damage to journals, it should be standard.
Old 11-10-2016, 05:00 PM
Be sure to measure everything. I mic the crankshaft as well as check the ID of the rod bearings as installed with a bore gauge, so I know exactly what my clearance is. If you use ARP rod bolts, you can torque them up to spec to measure with a bore gauge, and reuse the same bolts at final assembly.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 11-10-2016, 06:14 PM
TAV TAV is offline
Thanks for all the replies! Very helpful.
Old 11-11-2016, 02:15 AM
