MFI Filter Console
(C) 1972 Dr. Ing. h.c. F. Porsche A.G.
We are trying to completely refurbish and MFI system and looking at the Filter Console ITEM 6 is missing from the unit that we have installed on the car.
It is shown as a 'Shim' and is NLA.
Does anyone know its function and the correct thickness?
Old 12-02-2016, 07:17 AM
Chris, just a standard copper washer to seal the fuel. Just pulled one and it measures 0.9mm crushed. So a 1.0mm copper washer ill do. Hope this helps.
Rusty
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 12-02-2016, 11:35 AM
Item 12 is the 'seal' which is indeed a Copper Washer.
The 'shim' appears to be a separate part which is why I am confused.
Old 12-02-2016, 12:34 PM
Chris, I busted checked PET and see the shim, just checked 2 other units and neither of those have the shim. One unit is on my 70 S and worked as it should. Car is actually a 71E, just running a S engine. Didn't want to mislead.
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
Old 12-02-2016, 01:24 PM
I have checked 4 of them - none have the D****d shim either ???
Old 12-02-2016, 07:13 PM
