Crank shaft in-out allowable movement
While installing my fan in my 3.0 I noticed that when I ever so slightly pried a screw driver between fan shoud and lower crank shaft pulley to help seat and align the fan shroud, I noticed that the crank shaft moves in and out slightly when lighsly pried upon. Is this normal??
Antares
fatnwide
Old 01-14-2003, 10:00 PM
Author of "101 Projects"
Wayne 962's Avatar
Some slight endplay is normal, but noticeable end play is probably too much. I don't have the spec off the top of my head, but the crankshaft has a thrust bearing that should constrain the end play...
-Wayne
Old 01-15-2003, 01:59 AM
