| Registered |
				Crank shaft in-out allowable movement
			While installing my fan in my 3.0 I noticed that when I ever so slightly pried a screw driver between fan shoud and lower crank shaft pulley to help seat and align the fan shroud, I noticed that the crank shaft moves in and out slightly when lighsly pried upon. Is this normal?? Antares fatnwide | ||
|  01-14-2003, 09:00 PM |
| Author of "101 Projects" |
			Some slight endplay is normal, but noticeable end play is probably too much.  I don't have the spec off the top of my head, but the crankshaft has a thrust bearing that should constrain the end play... -Wayne
				__________________ Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports | ||
|  01-15-2003, 12:59 AM |
