-   -   Valve springs for 930? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/942691-valve-springs-930-a.html)
reclino 01-17-2017 09:05 AM
I am in process of a top end refresh on my 930, reground SC cams will go back in these heads. What valve springs should I put back in? Pelican has Porsche, OEM and German springs. I don't feel like I need heavy racing springs for this. Any suggestions from the engine builders, OEM and German are about $14 each. Porsche are about $40. Some of the springs in my heads have surface rust, so I would guess the cheap solution is replace at least the rusty ones, maybe all of them.
DRACO A5OG 01-17-2017 02:43 PM
Look for deals on Eibach Spring set. I found one for $85 on fleabay
Flat6pac 01-17-2017 05:44 PM
When the heads are done the springs are pressure tested to make sure they are in spec for closing pressures. OEM is sufficient.
Bruce
reclino 01-17-2017 06:07 PM
The springs have rust, that is death to a spring, they will fail. I won't put them back in the engine. I am looking for a set of Eibach springs 20701.212 evs springs. If I can't find that I will go with next best OEM spring.
reclino 01-18-2017 03:13 PM
Found a set of Eibach valve springs thanks to a helpful Pelican member.
Ryan H 01-31-2017 09:20 AM
