Valve springs for 930?
I am in process of a top end refresh on my 930, reground SC cams will go back in these heads. What valve springs should I put back in? Pelican has Porsche, OEM and German springs. I don't feel like I need heavy racing springs for this. Any suggestions from the engine builders, OEM and German are about $14 each. Porsche are about $40. Some of the springs in my heads have surface rust, so I would guess the cheap solution is replace at least the rusty ones, maybe all of them.
Thanks David |
Member 911 Anonymous
Look for deals on Eibach Spring set. I found one for $85 on fleabay
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
When the heads are done the springs are pressure tested to make sure they are in spec for closing pressures. OEM is sufficient.
Bruce |
The springs have rust, that is death to a spring, they will fail. I won't put them back in the engine. I am looking for a set of Eibach springs 20701.212 evs springs. If I can't find that I will go with next best OEM spring.
Found a set of Eibach valve springs thanks to a helpful Pelican member.
David |
2007 GT3 1982 911SC 1998 Integra Type R |
