New-ish 911SC Targa Owner
pampadori's Avatar
Name those rod bolts
Working on the slowest engine rebuild ever done, removed the rods and found these bolts. They don't have any markings that I can see on them. What brand might they be?
Also, they are 2.7 rods, right? Big end is almost 24mm thick.
Old 01-24-2017, 04:35 AM
pampadori's Avatar
I'll ask in different words what I'm really trying to learn. Do you think these are 1 time use or can I reuse these guys?
Old 01-25-2017, 07:05 PM
Mick_D's Avatar
never reuse anything you're unsure of.
Old 01-25-2017, 07:29 PM
Jeff Alton's Avatar
they look like ARP. If so they should have a marking on the head.
www.turn3autosport.com
Old 01-25-2017, 08:56 PM
pampadori's Avatar
no markings on them anywhere. I have emailed some pics to Raceware to see if they recognize their children or not. THey do appear to be treated or coated or something. They are darker than most of the other hardware. They "feel" very premium for whatever that is worth.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 01-26-2017, 07:29 AM
Mick_D's Avatar
If you really want to name them, you could use the names of the Dwarves from The Hobbit.
Let me see if I remember them:
Ori Nori Dori Oin Gloin Balin Dwalin Bifur Bofur Bombur Fili Kili - that's 12- and Thorin Oakenshield, in case you have a spare.
Though why you would want to name your rod bolts after dwarves is beyond me.....
Old 01-26-2017, 07:47 AM
The nuts certainly don't look like an OE part...
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 01-26-2017, 09:42 AM
kwikt 911's Avatar
Looks like rod nuts from a 968
Old 01-26-2017, 04:41 PM
Jeff Alton's Avatar
The 993 nuts look the same. After looking again, not ARP as I don't see a dimple in the bolt head to center a stretch gauge.
Cheers
Old 01-27-2017, 06:17 AM
It's a 914 ...
stownsen914's Avatar
Raceware? Here's a link to the Raceware ones that Pelican sells.
RACEWARE Connecting Rod Bolt Set PELRTE4004 - Raceware - PEL-RTE-4004 | Pelican Parts
Old 01-27-2017, 11:17 AM
