Seals in the rocker shafts???
Are there seals in the rocker shafts? When I dissassembled the motor there was no sign of them and when I reassembled I didn't put any in!!
Author of "101 Projects"
Only on the RSR engines, which used a slightly smaller shaft. I recommend installing them as a safeguard against leaks though...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Navin Johnson
those seals are cheap, about $2 ea. Its cheap insurance against oil leaks
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I don't even think they are that expensive...
http://www.pelicanparts.com/cgi-bin/autocat/load_page.cgi?page_number=2&bookmark=3&model=911M&currsection=enginC $1.50 each in our catalog... -Wayne
It is very easy installing them. I still wonder why they were only originally used on R engines.
Peter '13 981S '73 911T '05 996 4S cab, now gone '70 911S Targa, now gone |
They were used only on the RSR motors, because the RSR rocker shafts were slightly a smaller diameter. This was done for reasons I can't quite remember. I think it had something to do with the camshaft-fed oiling system, but don't quote me on that. Because the rocker shafts were slightly smaller, they leaked if you didn't use the seal...
-Wayne
Navin Johnson
Big deal, I said about $2 in any event its a whopping $12 savings.
Even if they seals were used by Porsche only on RSR motors. They are a good idea to use during any rebuild. The rocker bore can be damaged during rocker shaft removal. Unless you have a motor that has never been opened or rebuilt. You should use the rocker shaft seals. Its cheap insurance
I agree, cheap insurance...
-Wayne
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Does anyone know if you can put the seals in without removing the engine and if so hard hard is it?
Antares fatnwide |
I'm pretty sure you can do it without removing the engine - theoretically. I would definitely R&R the engine for this job. Tightening the rocker shaft bolts is hard enough with the engine out and must be a real b!tch with the engine in.
Yeah, it's possible, but it's a chore. I only did the exhaust half because that was the only ones leaking. You'll need a 5mm and an 8mm allen. The bolt has the 5mm head and that is the one you want to turn. I also used a piece of quarter inch copper pipe bent into an L-shape to help ease the shaft out of the bore without damaging the bore. I think all 911 engines should have these seals, at least on the bottom, exhaust shafts.
Marshall 75 911 3.2 |
You need 2 per rocker shaft, therefore a total of 24 seals.
And my 3.2 dosen't leak anymore
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
Senior Member
Glad you got those seals installed, Marc.
It makes you wonder why the Factory just didn't install them in the first place.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Well late than never. Finally got the car up and took both the exhaust covers and upper intake covers off. Thought it best to remove the side engine metal. The bottom rocker shafts ie. the ends of the rocker shaft and their perspective chamber are dry. No wet oil as a leaking rocker would be leaking in this area. The uppers appear dry as well except around one intake rocker which appeared to have some wettness around it's perimeter but no oil in chamber. Is this what a leaking rocker shaft looks like? I would expect more oil in the adjacent chamber. Externally, my dripping is at the head/cam tower junction. I am going to retorque the heads in a desparate effort to see if this will help. Otherwise I see no alternative to stop the oil migration. Perhaps the previous owner got the engine real hot and the head surface warped somewhat. Is this possible and usual? Otherwise I will drop the engine, remove cam towers and . . . yady yady yady
Anybody with input would be appreciated! Antares fatnwide |
Antares
welcome to the club. I had the exact same leak you are describing (see post Do steel cylinder head studs break?) In short, I re-torqued the heads, tightened the #6 exhaust rocker shaft slightly and replaced the covers with new gaskets. So far it seems dry, but needs more miles to verify. I am interested to know what you find on your engine. LeRoux
'90 964 C2 coupe (sold )There are no old Porsches, only new owners. |
Really, the only way out of this boat is to remove the cam towers and reseal the heads. I have an engine that has this leak too...
-Wayne
Check the cam oil line fittings. I too thought there was a leak at the cam housing and cylinder head joint. Instead, it was a loose fitting behind the distributor. Quarter turn tighter relieved me of all thought about how to stop the suspected leak w/o dropping the engine.
Sherwood Lee http://members.rennlist.org/911pcars |
Anyone got the part # for those seals ? Would like to get them to my rebuild and the Porsche dealer near me cant find them.
911.099.103.52 from page 118 in Bruce Andersons handbook. PET does not recognise this number though. You could also order them from our host, he should have no problems supplying them.
