-   -   Please help, cant find the oil gallery plugs in the enginecase (http://forums.pelicanparts.com/911-engine-rebuilding-forum/944260-please-help-cant-find-oil-gallery-plugs-enginecase.html)
Nine-one-one 01-30-2017 01:26 PM
Hi guys,
im in the process of rebuilding a 3.0 sc engine from scratch, but cant find new oil gallery plugs (the 22mm plugs that are pressed in on the right top side of the enginecase front and back).
Had them removed due to cleaning the cases from aquablasting to make 100% sure there is no blasting material left and the dirt from the last 20 years disassembed in a dirty shed is gone too....but i cant find them anywhere to buy.
They are about 22mm diameter and maybe 7-8mm long, made from alloy.
Is there a partnumber/source for them or do i need to have them machined....i mean im for sure not the first person to remove them :D
Will upload a picture later from my phone so you can see which ones i mean.
thanks in advance
AlexSmileWavy
Nine-one-one 01-30-2017 01:32 PM
:Dhttp://forums.pelicanparts.com/uploa...1485811827.jpg
http://forums.pelicanparts.com/uploa...1485811850.jpg
http://forums.pelicanparts.com/uploa...1485811895.jpg
http://forums.pelicanparts.com/uploa...1485811920.jpg
Upper two pictures show the position, lower two both sides of the plug, ignore the hole in the middle:D
Daugaard 01-30-2017 02:58 PM
Hi.
You can find them in PET under 996tt they are the same.
I just buy some to a 3,2 engine.
http://forums.pelicanparts.com/uploa...1485817084.jpg
Nine-one-one 01-31-2017 11:26 AM
Thank you a lot, thats a great answer, as they are pretty much the only part missing to complete the engine
Tippy 01-31-2017 12:25 PM
How did you get the aluminum so clean?? Looks brand new!
Walt Fricke 02-10-2017 08:24 PM
You can also tap the holes for the right size NPT inhex brass plug, and screw those in. Lets you do the next cleaning job more easily. The two you show should work fine, as there is plenty of length to tap before you start running into other oiling passages. Doing this with some of the other plugs requires great care and modification of the plug end and clocking. But not these two, I think. You can tell by looking into the hole.
