Forced Induction Junkie
WERK I's Avatar
Head to Cylinder Seating
I'm doing some pre-assembly work on my 930 engine. I recently had the heads worked on by Kelly-Moss (valve guides, exhaust valves, head sealing surface touchup). I just measured the gap between the two pads of the cylinder and head and came up with a gap of approx. .006" (.152mm). Does this seem excessive?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 03-13-2017, 10:39 AM
abit off center
cgarr's Avatar
Normally when cut you would also take off the same amount on that surface too. As long as there is clearance,
The depth of the sealing surface to the pad on the head should be around .100
______________________
Craig
G2Performance
Old 03-13-2017, 12:07 PM
WERK I's Avatar
Craig,
Thanks for your input, much appreciated. I had to remeasure the above dimension since I found a little valve lapping compound hiding on the head surface. The dimension is more like .005" after the cleanup. I was asking about this dimension to see if the head sealing surface would distort once the heads are torqued down.
The pads on the heads were touched at the same time the sealing surfaces were touched up.
Out of curiosity, is this process a one-step procedure when your cutting the heads? In other words does the machining cut both areas at the same with a special bit? Do you have a pic?
Dave
Old 03-13-2017, 12:21 PM
abit off center
cgarr's Avatar
I make 2 passes, sealing surface then the boss area with a .100 step.
Craig
G2Performance
Old 03-13-2017, 12:41 PM
WERK I's Avatar
Beautiful! Is that a special treatment you've applied to the combustion chamber?
Last question, promise. If I wanted to use the C2 Turbo Head Gasket (.025"), should I machine the sealing area of the head the same amount?
Dave
Old 03-13-2017, 12:51 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Master CGarr, will better answer this but from my understanding is to use the Flame Ring (964) gasket you need to accommodate cut the head to keep it in place.
'85 Carrera Targa
PCA/POC
Old 03-14-2017, 07:36 AM
WERK I's Avatar
The 964 Turbo Gasket (pictured below) is just that. A metal gasket that sits between the head and the cylinder. It's approx. .025" thick and sits nicely in the cylinder head recess. I don't know whether the cylinder head has to be machined an additional .025" to compensate.
A flame ring such as the Ni-Resist ring below requires machined grooves in both the head and cylinder.
Dave
Old 03-14-2017, 03:34 PM
WERK I's Avatar
Still no answer to this question about the C2 Turbo Head Gaskets. Maybe some background on this would help. This engine I'm rebuilding is an 930 3.3l that originally had the half-finned cylinders. The previous owner fried a piston AND cylinder so the Porsche shop put in a new set of C2 Turbo pistons and cylinders. The original 930 heads were retained. They did not mount the C2 turbo head gaskets.
I know there are far fewer C2 Turbo's out there compared to the total of 930 3.3 turbo's, so the knowledge pool on these heads might be more limited. It would great to know if the C2 turbo heads are different to compensate for the .025" of gasket material. Otherwise the compression ratio will probably drop a quarter point (.25). 7:1 compression is bad enough as it is.
Dave
Old 03-15-2017, 05:24 PM
abit off center
cgarr's Avatar
If you measure the sealing surface to the cam carrier surface it should be 84.5mm if the C2 heads are .25mm less that would be to adjust for the ring I would guess.
Craig
G2Performance
Old 03-15-2017, 06:15 PM
WERK I's Avatar
Thanks for replying, Craig. I'll measure the distance between the two surfaces. The only reason Porsche added the head gasket, from what I've read, was to address cylinder-to-head oil weepage on the C2 turbo's. I may forego the head gaskets if the heads are at 930 3.3l specs.
I'm using 993 TT head studs with 964 head nuts to help insure equal clamping across the cylinder under operating conditions.
Dave
Old 03-16-2017, 06:09 AM
Hi Dave, You need to have the heads cut to use the 964 head ring. Been there done that on the blue beast. Worth the trouble.
Old 03-17-2017, 08:11 PM
WERK I's Avatar
Dave,
Thanks for the advice. What hot projects you working on? Watched a couple of YouTube videos of you and 993 FabCar at RA. Great driving that beast!
Going to be in the shop Monday? Give you a call?
Dave
Old 03-17-2017, 09:06 PM
Yes, Give me a call.
Old 03-17-2017, 09:20 PM
