-   -   resurface 930 cylinder heads (http://forums.pelicanparts.com/911-engine-rebuilding-forum/944671-resurface-930-cylinder-heads.html)
MaRu 02-03-2017 10:24 AM
Hello,
I tried another company for resurfacing a set of 930 3,3 cylinderheads. I wasnīt attented when I picked them up, but today when I start assembling the engine I saw that they only cut the inside, but not the outer head surface. I checked with a feeler gauge and there is no play. I used new cylinders and they are 2.7 mm. The high difference in the head is 2.7 till 2.85. poor job, I will for sure not use them again. But what are the numbers I should have? Sorry for my poor english. Attached is a picture. I hope that makes it easyer to understand me. The blue numbers are the high differences. And this is where I need the original porsche numbers. I cannot find them in any of my book...
Many thanks in advance, Malte
http://forums.pelicanparts.com/uploa...1486146272.jpg
cgarr 02-03-2017 11:57 AM
They didn't go the full .25mm it looks like. The original surface should be 84.50mm. Those could be cut again and cleaned up, just adjust with a .50mm base gasket or what ever it takes. And yes the outer surface should have been cut the same amount or it can hit the cylinder fins.
Min would be 84.25mm
MaRu 02-03-2017 12:10 PM
Thank you! I am pretty sure they just cut till the surface looked good and didn t kept any eye about how much they cut them. Do you know the factoy difference between the inner and the outer surface?
cgarr 02-03-2017 12:15 PM
Every one I have measured is 2.50mm
MaRu 02-03-2017 12:57 PM
Thank you very much!!!
DRACO A5OG 02-03-2017 07:43 PM
a Plug for Master CGarr,
My heads masterfully done by him:
http://forums.pelicanparts.com/uploa...1483855168.JPG
http://forums.pelicanparts.com/911-engine-rebuilding-forum/941743-relax-have-cgarr-head-machine-rebuild-service-review.html
Most importantly, properly marked for future reference.
MaRu 02-04-2017 12:47 AM
Great job!!! But a little far away from germany...
Edelweiss 02-04-2017 02:27 AM
Germany
Where in Germany are you located ?
Best reg.
Dirk
https://www.facebook.com/edelweissmotorsport/
WERK I 02-04-2017 04:42 PM
Craig,
Would that same 2.50mm rule of thumb apply to the C2 Turbo heads that use a head gasket?
MaRu 02-05-2017 11:15 PM
Dirk, I īll give you a call this week.
Thanks, Malte
eulbeul 02-06-2017 08:34 AM
I had very good experiences with weil-motorentechnik.de
Give him a call. He is very knowledgeable and friendly.
Good luck,
Alex
