Main bearings pre-74 vs post-75
Hello
The Porsche catalog says the crankshaft bearing shell part number changed sometime in '75 apparently for all models from 901-101-132-00 to 911-101-133-00
What's the difference between these two?
Regards.
Old 02-22-2017, 12:12 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The only difference is the position of the tang.
Early cases can be altered to use either bearing.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-22-2017, 01:06 PM
Under the radar
Trackrash's Avatar
The locating tab on the bearing was moved.
If you could post a picture of your old bearings and or case the experts here can tell you what you need.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-22-2017, 01:09 PM
