-   -   head studs/ head wok (http://forums.pelicanparts.com/911-engine-rebuilding-forum/947523-head-studs-head-wok.html)
captain hook 02-26-2017 01:46 PM
Just figured out I have a broken head stud. did some quick research. what do you guys recommend?? Also there was a thread on here about a guy I think in michagan tht did really good head rebuilds and was reasonable with good turn around? cant find the thread now. Gunna do exhaust (probably rarely late) and itb I bought from al a whil back. have a completely "new" 915 with lsd and wevo parts ready to rock. Motor ran really strong, just saw a washer in fins. pulled cover and there it was. would keep up with 996 and 997s on spirted drives. hoping that means its solid aide from this.. slippy slope........
Tippy 02-26-2017 03:12 PM
cgarr
captain hook 02-26-2017 04:11 PM
Just googled cgarr. Didn't come up with anything. Can I get a bit more info. Thx
billybek 02-26-2017 04:38 PM
Pelican Parts Technical BBS - View Profile: cgarr
Try this link
Walt Fricke 02-26-2017 06:16 PM
cgarr = Craig Garrett (or is it just one T?)and he's in Grand Rapids, Michigan. That plus Google ought to get you the info you need to contact him. If nothing else, search posts here to find one he responded to, and use the private message system to contact him.
cgarr 02-26-2017 06:56 PM
Yea he got ahold of me thanks
DRACO A5OG 02-26-2017 10:20 PM
+10 cgarr!!!
brighton911 03-01-2017 02:52 PM
Craig did my heads and refaced my rockers as well. High quality work at a reasonable price. Go with confidence!
captain hook 03-05-2017 08:03 PM
Any point in opening case?. Motor runs great and has food oil pressure. Or is it more a " case" by " case" issue?
DRACO A5OG 03-05-2017 11:42 PM
How many miles do you have and what type of use?
captain hook 03-06-2017 12:17 PM
milage unknown, Ihave had car fro 1.5 yrs. dosent miss a beat, seems to use nxt to no oil. dosent drip.
DRACO A5OG 03-06-2017 04:23 PM
Hard to answer without mileage, what do you think the mileage is?
The reason I ask is it depends on wear of the bearings ergo main, rod and IMS.
If tracked even more critical
crashtest22 03-06-2017 05:16 PM
not to take work away from Cgarr as I have seen his work and its excellent but if your bay area Ted Robinson at German Precision and Jay across the parking lot do great work at a very reasonable price.
Walt Fricke 03-06-2017 09:10 PM
Capt.: From the clues in your posts, this car could be anything from a 1965 through a 1986 911. Starting in 1980 there was basically only one model (no S, E, or T) engine. When asking for advise it is always useful to include basic information like this.
strictly 03-07-2017 02:00 AM
is it a snapped stud? if so then if its snapped deep, and more snap as you take the top end apart, than you are MAY need to split the case to get them out (if welding to the old stud, dosent yield any results and they need to be bench drilled, etc).
To "asses" IMS without looking at it, A good clue will be how your cam sprockets look for wear, as the IMS sprockets will be showing similar wear...
Maybe do a leak down test before starting the tear down, just to help you assess the top end.
Top end is about 70% of the work, so maybe go the whole hog
captain hook 03-07-2017 07:31 PM
Car is a 76. Motor is 3.2 euro. 84. http://forums.pelicanparts.com/uploa...1488943864.jpg
DRACO A5OG 03-09-2017 09:48 PM
Purty :D
tharbert 03-10-2017 07:10 AM
http://forums.pelicanparts.com/uploa...1489158598.jpg
captain hook 03-11-2017 02:48 AM
Thx . Don't know why it kept going side ways.
porterdog 03-11-2017 07:12 AM
It's 'cause the engines in the back; consider it a feature.
