-   -   Show me your valve spring compressor (http://forums.pelicanparts.com/911-engine-rebuilding-forum/951815-show-me-your-valve-spring-compressor.html)
reclino 04-02-2017 07:17 AM
Looking for valve spring compressor's that work well on the 911. What is everyone using?
turbo nut 04-02-2017 08:14 AM
Heads on or Heads off?
Tippy 04-02-2017 08:36 AM
911 springs are very weak stock form. Those cheap, C clamp styles ones with the adjustable jaws should be fine.
JFairman 04-02-2017 01:27 PM
I have a C clamp type you use with the head off the motor that I got at Sears. It works OK with stock valve springs but it's a little flimsy so after market high performance valve springs are probably too much for it.
You get what you pay for and ebay would be a good place to look for a high quality used one.
cgarr 04-02-2017 02:59 PM
https://uploads.tapatalk-cdn.com/201...6710fba408.jpg
https://uploads.tapatalk-cdn.com/201...ae1987bd30.jpg
reclino 04-02-2017 06:38 PM
I bought a C-clamp yesterday to do that. Thanks for the pix
Jon B 04-02-2017 11:53 PM
http://forums.pelicanparts.com/uploa...1491202245.jpg
boyt911sc 04-07-2017 07:02 PM
P7E & P7I valve spring compressors.....
These are P7E and P7I valve spring compressors used by shop or race mechanics to quickly inspect and test valve springs or bent valve/s for assembled motor.
http://forums.pelicanparts.com/uploa...1491616922.jpg
Tony
Jon B 04-07-2017 11:18 PM
Originally Posted by boyt911sc (Post 9542677)
These are P7E and P7I valve spring compressors...
Those are available from Pelican, order numbers PEL-TOL-P7E and PEL-TOL-P71.
They're designed to attach to the cam towers.
