Show me your valve spring compressor
Looking for valve spring compressor's that work well on the 911. What is everyone using?
David |
Heads on or Heads off?
Chain fence eating turbo
911 springs are very weak stock form. Those cheap, C clamp styles ones with the adjustable jaws should be fine.
I have a C clamp type you use with the head off the motor that I got at Sears. It works OK with stock valve springs but it's a little flimsy so after market high performance valve springs are probably too much for it.
You get what you pay for and ebay would be a good place to look for a high quality used one. |
abit off center
![]() ![]() Sent from my iPhone using Tapatalk
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I bought a C-clamp yesterday to do that. Thanks for the pix
David |
Jon B. Vista, CA |
P7E & P7I valve spring compressors.....
These are P7E and P7I valve spring compressors used by shop or race mechanics to quickly inspect and test valve springs or bent valve/s for assembled motor.
![]() Tony |
Those are available from Pelican, order numbers PEL-TOL-P7E and PEL-TOL-P71.
They're designed to attach to the cam towers.
Jon B. Vista, CA |
