New fasteners ?
1987 3.2 non T
Which fasteners need to be replaced when doing and upper end rebuild ? I've got 12 new bottom head cylinder studs. Is stretching something to check for on the top studs ?
1987 911 Carrera Coupe 1987 Buick Grand National 1971 Plymouth Roadrunner |
Top row are steel, never a problem.
Bruce |
Hmmm... okay. I measured mine a few weeks ago and if i'm remembering right, they were sticking out 139mm Thought that was beyond spec.
Would they be an issue, Bruce, it they are corroded to the point of pitting?
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
The pre 3.0 can get rust because they are in the open air. The 3.0/3.2 are enclosed in the cylinder.
If pits are a concern, change them out. Bruce |
