98mm P&C's on a 3.0 case
Is it posible to put bored out 3.2 cylinders to 98mm on a 3.0 930 Turbo case?
Yes, the Carrera and SCs cylinders will fit as the 98mm are Carrera cylinders.
Bruce |
Can I still use 3.0 heads with 3.2 cylinders?
Yes, the 98s should have started as 3.2 cylinders such as the 3.3 turbo 97mm are opened 95mm
Bruce Last edited by Flat6pac; 07-04-2017 at 11:22 AM.. |
motor
Hi,what are you building?Fred
I have a 930 Turbo 3.0 case that Im planning on building. I have 3.2 cylinders and J&E 98mm pistons 9.5:1
