DC20 cam
Hi pelicans.
Someone now the settings? I want to install DC20 cams in my 2,7 rs, but i can't find the overlap settings. The cams are DC20 104 lobe center. Thanks |
Dougherty Racing Camshafts have the info
Dc20
I hope someone have some info on this.
On John's site there are no DC20 listed with 104 lobe center. Thanks |
His name is camgrinder here on Pelican. Send him a PM and he should give you an answer.
dc20
I have sent camgrinder a pm but no answer.
I really need to find the settings now. With a lobe center of 104, it must be special grinding. Can I use the degree scale to find settings? Or set inlet and exhaust even when overlap? Some who have suggestions? Thanks |
Or Google "Dougherty DC20" and a number of Pelican posts come up that have your answer. Tried posting the links yesterday but didn't get them past the moderator!
These were a custom ground set. He has the setting now.
DC20 cams
Just a little late feed back.
Thanks to John Camgrinder for providing the correct specifications. I would set these up at 3.4mm. These cams are more aggressive vs. the 911 E. Fall between the solex and 911 S profiles. 248/236 @ 1mm with .470 / .450 "valve lift. 104 lobe separation angle. I was busy getting the engine done. The car should drive historic hill climb and the engine in the car was 3.2 and not allowed. I thought the car would be slower with 500 cc less a comp. ratio 2 points lower. But no, the little 2.7 is much livelier from 5000 rpm and 20 kg less. The car won 7 hill climbs in 2017 and became champion in Denmark in historical class. http://forums.pelicanparts.com/uploa...1516486075.jpg |
That is a Fine looking car Daugaard. I'm also really happy with cams John did for me. Great performance and holding up just fine (no pitting etc).
Well done.
Porsche 911 2.7 RS
Awesome - looks good.
Congrats. Please come and join in the historic race.? Thanks - Cheers - Olsen911 Tommy Olsen |
| All times are GMT -8. The time now is 03:57 PM. |
