Daugaard's Avatar
DC20 cam
Hi pelicans.
Someone now the settings?
I want to install DC20 cams in my 2,7 rs, but i can't find the overlap settings.
The cams are DC20 104 lobe center.
Daugaard
Old 07-09-2017, 02:05 PM
Chain fence eating turbo
Dougherty Racing Camshafts have the info
Old 07-09-2017, 04:02 PM
Daugaard's Avatar
Dc20
I hope someone have some info on this.
On John's site there are no DC20 listed with 104 lobe center.
Daugaard
Old 07-10-2017, 02:02 PM
KTL KTL is offline
Schleprock
KTL's Avatar
His name is camgrinder here on Pelican. Send him a PM and he should give you an answer.
Kevin L
'86 Carrera "Larry"
Old 07-10-2017, 02:55 PM
Daugaard's Avatar
dc20
I have sent camgrinder a pm but no answer.
I really need to find the settings now.
With a lobe center of 104, it must be special grinding.
Can I use the degree scale to find settings? Or set inlet and exhaust even when overlap?
Some who have suggestions?
Daugaard
Old 07-15-2017, 03:48 PM
Dc20 cam timing
Old 07-16-2017, 02:28 AM
sp_cs's Avatar
Just call him -
Shirish
1987 Carrera, Granite Green
Old 07-16-2017, 04:45 AM
Or Google "Dougherty DC20" and a number of Pelican posts come up that have your answer. Tried posting the links yesterday but didn't get them past the moderator!
Old 07-17-2017, 01:26 AM
camgrinder's Avatar
These were a custom ground set. He has the setting now.
John Dougherty
Old 07-17-2017, 03:11 PM
Daugaard's Avatar
DC20 cams
Just a little late feed back.
Thanks to John Camgrinder for providing the correct specifications.
I would set these up at 3.4mm.
These cams are more aggressive vs. the 911 E.
Fall between the solex and 911 S profiles.
248/236 @ 1mm with .470 / .450 "valve lift.
104 lobe separation angle.
I was busy getting the engine done. The car should drive historic hill climb and the engine in the car was 3.2 and not allowed. I thought the car would be slower with 500 cc less a comp. ratio 2 points lower. But no, the little 2.7 is much livelier from 5000 rpm and 20 kg less.
The car won 7 hill climbs in 2017 and became champion in Denmark in historical class.
Daugaard
Old 01-20-2018, 02:08 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
That is a Fine looking car Daugaard. I'm also really happy with cams John did for me. Great performance and holding up just fine (no pitting etc).
1986 Targa Guards Red
2021 MT09 SP
Old 01-20-2018, 04:22 PM
gearhead
Well done.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-20-2018, 05:14 PM
Olsen911's Avatar
Porsche 911 2.7 RS
Awesome - looks good.
Congrats.
Please come and join in the historic race.?
Thanks - Cheers - Olsen911
Tommy Olsen
“I will not demonstrate it, I will race it.” Juan Manuel Fangio
Old 01-21-2018, 02:08 PM
