Crotchety Old Bastard
RarlyL8's Avatar
2.2L MFI Build Question
Our shop is building a 911ST clone and the donor car is a 1971 2.2L MFI 911.
Question is how far can we expand the displacement of this engine?
I'm thinking 2.5L would be a nice bump with high compression.
Old 07-21-2017, 07:43 PM
Under the radar
Trackrash's Avatar
How big? You mean with mostly standard Porsche parts, I guess.
My recently retired, (and for sale), motor was a 2,5 based on a 2,2 T motor. It used 2,7 Mahle 90mm P&C and the stock 66 stroke crank. The heads and case had to be machined for the larger cylinders. The heads also had to be chamfered for the larger pistons. The cylinder seating surfaces get thin, but it did not cause any problems with my motor over two decades of use.
You could also install a 70mm (2,4 or 2,7) crank and rod set for a 2,7 displacement.
You could also, ( I assume) install overbored 2,7 cylinders and go up to ( I think) 2,8 or 2,9.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-21-2017, 07:58 PM
gearhead
Yes. 2.4/2.7 crank and 1mm overbore. I think Henry at Supertec has done a ton of them.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
RarlyL8's Avatar
Second question; what is the expansive capacity of the 2.2L MFI? Can it be adjusted to fuel 2.5L?
Old 07-21-2017, 08:40 PM
3 restos WIP = psycho
kenikh's Avatar
85mm on a 66mm crank is the original config for an ST (2.3L). Later STs ran 2.5L in both short (66mm) and long (70.4mm) stroke. The MFI pump and lines are fully capable of supporting over 3L in displacement with space cam swap.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-21-2017, 09:06 PM
kenikh's Avatar
Long stroke used 86.7mm pistons.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-21-2017, 09:08 PM
gearhead
If you do short stroke the case will need to be machined to accept the big bore cylinders. Is the customer on with that?
1974 914 Bumble Bee
2009 Outback XT
Old 07-22-2017, 01:25 PM
