Under the radar
OK, so it's a Turbo, I missed that, douh. Not sure about using steel head studs on a Turbo. I thought you had and SC....
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 07-27-2017 at 09:59 AM.. |
If I need to get the fancy ones I can...just making sure its necessary... |
Under the radar
Are the upper studs Divilar?
Looked up the paperwork on my car from a po, said it made 400hp with higher boost.... I know he was runnin over 1 bar... My goal is 0.8 bar on the track, 1 bar on the street... Is that in territory for stock steel studs? Or is that beyond that? |
On a street car, either will work. I still like the fine threads on the end of the supertec.
Why the Porsche didn't do it, they went that way on the through bolts but not on the head studs. Bruce |
