-   -   Gasket sets, any difference? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/965291-gasket-sets-any-difference.html)
bpu699 08-03-2017 11:15 AM
All inclusive top and bottom end gasket sets. Porsche, Erhling, Wrightwood Racing, Victor Reinz, etc...
Any appreciable difference? Prices about the same...
Only negative I saw mentioned was that VR oil pump rubber connector may be too short...
sebastianroher 08-03-2017 12:11 PM
I was told by a good friend that Wrightwood gaskets were the best. That's the route I went with. My friend owns his own Euro repair shop and is heavily involved with the early cars. Hope this helps.
DRACO A5OG 08-03-2017 12:26 PM
+2 Wrighwood Racing, don't chance it
Tippy 08-03-2017 12:32 PM
I had luck with Victor-Reinz, but going 100% Wrightwood Racing this time.
Apparently, VR had a problem with the oil seals in between the case havles causes the oil pump to cavitate. Uh, that's really, really bad.
eastbay 08-03-2017 12:59 PM
I'll be the contrarian, I used Wrightwood on my last rebuild and have multiple gasket and o-ring failures since cured by other brand gaskets and rings.
bpu699 08-03-2017 01:09 PM
Hmmm... clear as mud....
Anyone buy the "Porsche brand" gaskets? Or is that just pissing money away...?
Tippy 08-03-2017 03:40 PM
I believe it's pretty unanimous in regards to all the big builders on this forum to use only Wrightwood.
bpu699 08-03-2017 04:26 PM
Sounds like wrightwood gets the nod...
Thanks guys...
I see wrightwood makes a case gasket set... But nothing for the heads?
Am I missing something?
Tippy 08-03-2017 04:36 PM
They make both
Turbo_pro 08-03-2017 04:41 PM
Supertec has a the Wrightwood Racing inventory on their website
Porsche Parts Sales
bpu699 08-03-2017 04:51 PM
Porsche Parts Sales
Website only lists Oem and Viton?
Is the gasket set for a 930 different than a non turbo? It's the same block and heads, confused...
Is the victor reinz only an issue with the oil pump seals? $296. Porsche $400. Oem? $650?
Not trying to be cheap, willing to spend money where it matters. But that's a huge price spread...
Mike R. 08-03-2017 05:51 PM
call Ken @ vintage911parts.com
he works for Henry @ Supertech
he will give you the current pricing for your application
Tippy 08-03-2017 06:37 PM
Pelican carries them, you just have to search
