Piston rings for KS pistons
Hello, trying to find some piston rings for KS 2.7 pistons, any ideas who might have some, part numbers would be good too.
Old 08-15-2017, 02:49 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! If our members are not able to help you source some, please feel free to give us a call at 888-280-7799 and one of our Porsche part specialist will be happy to assist. Hope this helps a bit and best of luck!
Old 08-15-2017, 10:34 AM
Recommend you keep the old rings as alucil doesn't like new items to rub it wrong..
Bruce
Old 08-15-2017, 01:21 PM
Bruce
Decided because I am building to sell the engine I will not take any chances and will purchase new Mahle pistons and barrels. Took all the pistons out which was not a good move, also had the external parts of the barrels vapour blasted...
Old 08-15-2017, 02:09 PM
You might reconsider the Mahle thought and send the cylinders out and open to 92mm @2.8 and add JE 9.5, about the same money.
At that rate your customer has something to build on, carbs, cams, etc
Bruce
Old 08-15-2017, 03:17 PM
