| Registered Join Date: Nov 2003 Location: Naperville, Il
				993 Cam Repairs
			One of the cams from my stock 993 3.6 sustained galling damage to a couple of lobes.  Who is the best "go to" shop for repair of the cam.  Since the damage is isolated to two lobes and about the size of a dime on each lobe, I believe the cam is salvageable.   Many years ago, I had an oil starvation failure of one the early pressure fed cams from an early 911. I was able to get a shop to weld up the damaged lobes and then they were able to regrind the repaired areas. That repair lasted for at least 60k miles until I sold the car, so the weld repair appeared to be successful.
				__________________ Ernie 98 993 C2S - Arena Red/Beige 76 914/6 3.2 Conversion - Estorill Blue/Coral Red | ||
|  09-11-2015, 06:18 PM |
| Registered Join Date: Jul 2001 Location: Portland Oregon
			Webcam,....great job, really nice people. The real issue is finding out WHY this happened otherwise you will enjoy an 'encore' performance.
				__________________ Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com | ||
|  09-11-2015, 09:19 PM |
| Registered |
			I have a few sets if you want to go that route.  Just saying . . . R
				__________________ 1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer | ||
|  09-11-2015, 10:23 PM |
| Registered Join Date: Apr 2007 Location: wisconsin
			Bringing an old thread back... When you have one pitted lobe, what are the repair options? Does webcam repair and grind just the one lobe? Do they weld and just grind the repair area? Do you grind the whole cam? Both cams? If not just one lobe, what's the rationale? | ||
|  08-15-2017, 04:55 PM |
