Chain fence eating turbo
Cam tower bores and effects on oil pressure
Thought has crossed my mind. I've been trying to figure out why my oil pressure has been lower than I like on my 3.2 (3.4) at idle when hot (it'll dip below 1-bar at 900RPM). It has a turbo, so oil pressure is feeding the turbo and it already has the restrictors on the cam tower lines.
What dawned on me, is the bores for the cam journals are pretty grooved.
Anyone have any insight on the effects on oil pressure due to this?
Second, has anyone sleeved these bores?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 09-01-2017, 09:21 AM
Interesting questions... I thought the cam bores were just "splash" fed? Are there oil galleys going to them?
My motor is in pieces, will need to check...
I told my cousin, a mechanic, that the 930 cams rode in an aluminum bore, with no bushing... He didn't believe me...
Old 09-01-2017, 10:58 AM
Hmm, I always assumed pressure fed, but you might be right? If that's the case, this is the most useless thread ever! 😂 😂 😂
Old 09-01-2017, 11:18 AM
Under the radar
Trackrash's Avatar
I think this is a good question, since no one ever talks about cam bearing clearances.
The cam journals are sort of pressure fed. That is, the pressure in the squirter tubes feeds the cam bearings.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-01-2017, 11:56 AM
Yep, that is what I found too. I had to Google at work.
The spray bars feed. I'd thibk with that much surface, it'd have to be fed and not splash if you will, no?
Old 09-01-2017, 11:59 AM
The cam towers are spray bar fed and there are really tiny bores that spray oil here. The cam tower bores being scored will not affect your oil pressure.
If you have low idle oil pressure (i.e. below 1 bar) it's not really a concern unless you don't also have 1 bar per 1K rpm running oil pressure. The gauges aren't that accurate in the first place.
If it is a concern, there are 2 things you should check:
1. Whether you have the spacer in the oil pressure relief valve (the one on the bottom of the motor)
2. What kind of oil are you running. Lower weights mean lower pressures.
Old 09-01-2017, 12:33 PM
